1 - 20 of 34 Posts
Alright so someone offered to purchase my subwoofer
So I began planning my next setup
two JBL GT1041D powered by an Audiobahn A4002T Amp
power would be 200 watts per, 75 watts lower than RMS rating
but the box is the big question
outer dimensions would be 26 x 12 x 18, inner would be 24.5 x 10.5 x 16.5
the volume would be about 2.5 cubic feet (after subtracting port volume and adding 30% for stuffing)
I wanted to reverse mount them, one on either side of the box.
So I wondered since they are firing at one another should they be wired as if it were isobaric loading?
If not I remembered hearing that two sound waves of the same frequency colliding would cancel each other and become a small amount of heat
Also I remember hearing a sub wired in reverse polarity (or correctly in the case + to +, - to -) would sound bad
Anyone with any ideas?
just wondering what your willing to pay for sub and amp? the sub you picked is o.k. and the amp kinda sucks it mite put out that 150 of that 200 watts rms.
also are you talking a clam shell configure if so the clam has to be push one sub and pull the other you do not get louder but deeper bass from that configure
and if your talking a ported with one facing out and one in you get no gain in output from doing so and loose out put. if any thing but they got to be push pull or you cancel out what work the piston does which lowers volume big time. i do not recomend doing this so any ways. i think it is better with push push set ups but it is up to you.
also what about reverse mounting them in a band pass set up.
Listen to what Sadistic has to offer. Changed my perspective on car audio :woot: But honestly the Kenwood you had would be a better option. I would keep it and make a custom ported box with a better amp then you had that will give it the 400rms its rated for. I had three of those Kenwoods and they were pretty good subs and went through some hell.
QUOTE (sadistic @ May 24 2010, 10:25 PM) index.php?act=findpost&pid=806693
also what about reverse mounting them in a band pass set up.[/b]
I was thinking clam shell but I was wondering if it should be push push or push pull, sorry for the vauge description
I currently have one kenwood KFC-W3012 powered by the Audiobahn A4002T (Bridged for 400 watts RMS) but, I'm selling the sub for twice the price I bought it for :D
I could buy two of them for a similer price and create a custom box but my amp couldn't handle it...
I was planning on a reverse mounted setup to increase the net box volume, though a fourth order bandpass sounds fun :thumb:
QUOTE (Kiddchaos @ May 25 2010, 11:57 AM) index.php?act=findpost&pid=806796
a clam shell is when you mount one speaker to the other so the magnet stick out and the other in the box but it will be a single hole box for one woofer. and have to be push pull so not to damage the speaker. same is true for a two hole sub box were the sub have one magnet in one out has to be push pull wired. is there a dollar amount you would like to spend there are good deal on phenoix gold rsd amps and subs , soundstream rubicon amps , sony xm-9001gtr, and alpine mrp-500 alpine type r subs can be found under $99 amps most amps can be found under 200 and put out gobs of power. i do not think your looking at brand like audioque, sundown, ssa, sound splinter,stesom, mach5audio etc.... i get them at amzon /ebay for the cheap ones and ssastore .com etc for the other brands check the manufacture web sites.
oh ya forth order band pass all the way
herer is some amps to look at i tried to kep it low priced this is why i did not suggest a sundown sae1000d etc... any ways i think the best one i found was the first sony listed any ways hope these help and yes that sony putout 600+ watts rms unlike a 1000 watt sundown that put out 1200 -1300 rms but for 99 dollars not bad
http://cgi.ebay.com/NEW-SONY-XM-ZZR3301-11...=item414f571bd2
http://cgi.ebay.com/SOUNDSTREAM-RUB1-700-M...=item518b53e9a5
http://cgi.ebay.com/JBL-BPX5001-CAR-AMPLIF...=item58877a5b41
http://cgi.ebay.com/NEW-ALPINE-MRP-M500-MO...=item4aa18c118c
http://cgi.ebay.com/Cerwin-Vega-V-500-1-Ca...=item1e5c1662d1
http://www.millionbuy.com/cevvega5001.html
http://www.millionbuy.com/rocr5001.html
http://cgi.ebay.com/MTX-600XD-MONO-D-1200W...=item35a97b7877
Clam shell as in Isobaric Loading? I was thinking one sub on either side of the box firing at one another both with magnets out.
I have looked at audioque, and mach5 but I'll check out the other ones too
I usually try to keep my amps under 100 dollars by buying used
(I can't justify 200 dollars for a new amp when a 50 dollar one can achieve the same result)
Discussion Starter · #8 ·
QUOTE (sadistic @ May 25 2010, 10:04 PM) index.php?act=findpost&pid=806913
http://cgi.ebay.com/MTX-600XD-MONO-D-1200W...=item35a97b7877[/b]
thanks for the recomendations, these are a little high for me but some look like they'd be worth saving for with the massive amount of power for the price
QUOTE (Kiddchaos @ May 25 2010, 10:23 PM) index.php?act=findpost&pid=806931
i would check in to the sony i seen it for 119 with free shiping. also did not have time to try amazon i will in a minute for the sony ya clam shell or iso does not work that great so i would not suggest it. but the way you talking two magnet facing out is fine to do they just do not get as loud and you still wire them in the push - push method or parallel them. any ways i will look for a sony on amazon for you.
Discussion Starter · #11 ·
So i'd be better off with a larger box, both magnets in?
QUOTE (Kiddchaos @ May 25 2010, 09:19 PM) index.php?act=findpost&pid=806930
(I can't justify 200 dollars for a new amp when a 50 dollar one can achieve the same result)[/b]
What 50 dollar amp outperforms a 200 dollar amp? If you can't justify spending over 100 bucks on an amp I'd suggest a new hobby. :huh:
Discussion Starter · #13 ·
QUOTE (adio @ May 26 2010, 02:16 PM) index.php?act=findpost&pid=807033
I have yet to spend over fifty for and amplifier
Memphis PR 100.4 - $20
Audiobahn A400T - $50 - overheating issues
Dual (Model unknown) - $30 - Crappy btw
Scosche (Model Unknown) - $40 - blown from lack of knowledge
I will agree withe everyone the Dual and Scosche Amps aren't even decent but these were before I learned anything about car audio, I was looking for cheap like anyone who doesn't know about car audio when they start
the Audiobahn A400T has served me well, except on hot days
and I have only one issue with the Memphis Amp, the crossover for the rear channel was broken when I got it but for $20 it was a steal
QUOTE (Kiddchaos @ May 26 2010, 11:25 AM) index.php?act=findpost&pid=807008
So i'd be better off with a larger box, both magnets in?[/b]
yes .
QUOTE (adio @ May 26 2010, 01:16 PM) index.php?act=findpost&pid=807033
very true but you can find use sonys for cheap too that why i suggest this amp as a start but like he said you picked the wrong hobby if you dont want to spend on the amp.
Discussion Starter · #15 ·
well unfortunatly for me, I''m still 18 and I'm a delivery guy. A little more money than before but not as much as I'd like for my hobby
hopefully when I'm older money won't be such a factor
Discussion Starter · #17 ·
QUOTE (sadistic @ May 26 2010, 05:52 PM) index.php?act=findpost&pid=807099
QUOTE (Kiddchaos @ May 26 2010, 04:45 PM) index.php?act=findpost&pid=807065
hopefully when I'm older money won't be such a factor[/b]
good point that is the way to do it then.
well back to the box then
I measured the space I have (4th gen Taurus SES)
it was 37x18x12 (correct me if someone found different sizes)
do you have any knowledge I should know on designing a 4th order bandpass, vented, or sealed box?
I was also considering a spare tire enclosure if you would recommend it
Are you sure this dimension actually fit in the trunk? Biggest box I've had so far was 36x14x16. Just make sure that your measurements clear the opening
My box is 33x24x16.5 Can't go much bigger than that besides the width, which can be like 3-4 inches wider.
1 - 20 of 34 Posts
