1990 Taurus GL
When I make hard left turns from a dead stop the drive action stutters (like it's failing to shift but tries 3 or 4 times) while shifting into second.
I'm thinking my gears/linkages could be worn down. I'm going to have to replace my tranny fluid soon as it's been near 30,000mi since I got it.
I was talking to my friend who mentioned the worn internals and said if I were to flush the tranny I could kill it. Also they mentioned using Lucas Transmission Fix solvent to buy me some time, but I think this stuff sounds like a scam.
Help, I'm a bit confused as to why this would only happen going into left turns. (it also doesn't consistently happen)
AfrikaansAlbanianArabicArmenianAzerbaijaniBasqueBelarusianBulgarianCatalanChinese (Simplified)Chinese (Traditional)CroatianCzechDanishDetect languageDutchEnglishEstonianFilipinoFinnishFrenchGalicianGeorgianGermanGreekHaitian CreoleHebrewHindiHungarianIcelandicIndonesianIrishItalianJapaneseKoreanLatinLatvianLithuanianMacedonianMalayMalteseNorwegianPersianPolishPortugueseRomanianRussianSerbianSlovakSlovenianSpanishSwahiliSwedishThaiTurkishUkrainianUrduVietnameseWelshYiddishAfrikaansAlbanianArabicArmenianAzerbaijaniBasqueBelarusianBulgarianCatalanChinese (Simplified)Chinese (Traditional)CroatianCzechDanishDutchEnglishEstonianFilipinoFinnishFrenchGalicianGeorgianGermanGreekHaitian CreoleHebrewHindiHungarianIcelandicIndonesianIrishItalianJapaneseKoreanLatinLatvianLithuanianMacedonianMalayMalteseNorwegianPersianPolishPortugueseRomanianRussianSerbianSlovakSlovenianSpanishSwahiliSwedishThaiTurkishUkrainianUrduVietnameseWelshYiddish
Detect language » English​
1990 Taurus GL
It's a little bit over. Fluid is a pink color.
1990 Taurus GL
No thoughts on this? Any opinions on that Lucas Transmission stuff? Also sorry about all the extra text. The forum here seems to pick up my HyperTranslate as text rather than a program...
There is a bug with the Hypertranslate add-on. Disable it when you use these HTML forms and it should fix the problem with garbage text.
