What could this be? After awhile of driving with the windows up and A/C on I noticed a strong gas smell in the cabin. Also noticed it towards the rear of the car.
there are no leaks detected anywhere in engine bay or near gas tank.
- possible fuel filter? I know it is probably pretty old.
- gas cap is holding pressure in like it should
- any ideas ? thanks
no LOL my car is lucky to ever see a full tank with these gas prices
I was wondering where the charcoal canister was located..I am sure it is the original 16 yr old one so it wouldn't hurt to check it
my problem was that the seam of the nipple, that comes out of the fuel pump assembly, connects to the high pressure hose, and in turn the hose connects to fuel filter. the seam came undone, so with fuel pump pumping the gas would seep out. I used a expoxy for plastic from autozone, holds up to 9600psi, works so far. No needs to buy a whole new fuel pump and assemply, use the cheapest way first. I had to hook the power to the pump, after i brought tank down to find out where it was leaking from
