· Registered
Hello.
So, basically, my car won't start, and we don't know why. We've measured the mA of the battery, and it's usually 12.37 while turned off (which is a change from when it was being drained by something...). Now the problem is that it won't start period, unless a jump is used, in which case it runs perfectly on the road. Now, for all of you experts, this is what's happening:
The battery will actually rise now on its own, but even with 12.36mA, it won't start, and when we do try to start it, it just does that super-fast "click"ing noise from the get-go. After trying to start it, we checked the mA of the battery, and it was ~10mA. Tried it again, and it went down to ~6mA. After a short period of time it rose to ~12.3mA again...we're totally at a lose as to what's happening now. Seems as though whenever we try to turn on the car, it just sucks a massive amount of juice from the battery all at once.
Any help would be GREATLY appreciated, as I can not drive my own car until it's fixed...blah...
· Registered
mA is the abreviation for milliamps - and you're giving numbers for voltage. so I assume you're reading the wrong scale on a multimeter. More than likely your battery is near dead - or your battery terminals are coroded. Jump start the car and bring it to an auto parts store (Advance or Autozone or another) to have them check the battery.
· Registered
Right, my bad. Is there a possibility that it's the starter? It's had 142k miles on it, and it was a fleet car for 141k of those miles...
Oh, and we just replaced the old battery about two or so months ago.
· Devoted Member
Yes, especially if the battery is new. Worn out starter windings can draw a lot of current, to the point where a good battery can not deliver enough Cold Cranking Amps to turn it over unless jumped with another battery ( higher CCA, 2 batts. in parallel) Starter is not that hard or $ to DIY, but have your alternator/charging system checked for free by Advance or AZ first.
