1 - 2 of 2 Posts
just as the title says. Thing is it only sitcks when I first turn the car on. I have to give it a good poke to get it loose. Is there a certain point I should lube up so as this does not happen. Not really a big deal but just wondering where to lube it. thanx
QUOTE (echarleswhyte @ May 17 2009, 07:59 PM) index.php?act=findpost&pid=725914
just as the title says. Thing is it only sitcks when I first turn the car on. I have to give it a good poke to get it loose. Is there a certain point I should lube up so as this does not happen. Not really a big deal but just wondering where to lube it. thanx[/b]
Clean your intake, the metal circle where the butterfly is... This should fix the issue... My guess is that oyu live down a gravel road, or drive under dusty conditions allot...
Otherwise I all out of suggestions... other than you need a new throttle cable if yours is busted and rusty... the cleanup is no more than ten minutes of workm adn $3.99 for a can of throttle body cleaner...
1 - 2 of 2 Posts
