I stumbled into this car when the PO abandoned it at a local repair shop because the brake lines rusted out under the driver's door. But it ran perfectly, had barely any body damage, no other leaks, and was very clean inside, so I couldn't pass it up. This makes my 8th vehicle currently, after 3 '93-95 Broncos, 3 '93-97 F-series, and an '03 Ranger (which needs a cab).
So like the trucks, I plan to modernize this inside: touchscreen, BT, AndroidAuto, wireless cradle, backup camera, dash cam, USB power, seat heaters, TPMS... Then I'll drive it until someone makes me sell it. I'm cataloging most of the parts I have bought (or WILL buy) on an Amazon list, even if I'm buying them elsewhere, because Amazon pages are more-stable over the years.
Of course, job 1 was the brake lines. I didn't feel like figuring out which one was leaking, so I just replaced both using a Carlson H8300 coil.
The nuts were fine, so I just transferred them to the new tubes - everything went together easily.
I think I spent more time bleeding than changing the tubes, but the calipers were so rusty that I had to sandblast the brackets so the pads could move. While I had things apart, I blasted the rotors, and the front hubcaps (which I then painted & clearcoated).
An exhaust hanger was broken; the pollen filter looked almost factory; the (DuraCrap) battery was shot; the hood struts were weak; the headlights were foggy;
The cheap tires are OK, as are the belt & air filter. But I'll probably change the oil & coolant soon. I haven't decided about the ATF & PSF. I need to clean the instrument cluster, so I might change most of its bulbs to LED, like I've already done to the (new) headlights & CHMSL. I need to track down a replacement lid for the flip-up console, though.
