So yeah, my clockspring went bad, I got a replacement, took the airbag off, no problem. Tried removing the steering wheel with a steering wheel puller and it totally ###### it up. Rather than pulling the steering wheel off, it pulled one of the outer bolts out of the threads, totally stripping it out. How do I get the steering wheel off now? I want my horn back...
Drill and tap out the damaged area to the next size up thread. Make sure you run the bolts down all the way, if they only go in part of the way it is more likely that they will pull out.
If you don't know what he's talking about, better take it to a shop that can do it for you.
