Hey guys, yesterday my Sable 3.8L (automatic) after driving it to a couple of places I turned the key to start it but the starter wouldn't crank! after I played with the Ignition Key on/off, pressed the brake pedal several times and moved the Trans stick from P to 1 and backwards like 20 times or so the car finally started. Battery is ok and I always see the dashboard lighted everytime I turned the key, after that incident it started normally 4 times more as if nothing happened and I was able to make it home. It was very scary since I was parked in a desolate area of my city at night!
Question: Is there some kind of switch or safety lock damaged that can be preventing the starter to crank sometimes? I don't want to end up in the middle of nowhere with a dead car HELP!
