· Registered
tested the the relay and it works good. the car sat in freezing temps for 2 weeks. never had a starting problem. today it warmed up (34 degrees) and when i went to start it the starter sounded like it went to roll and it stopped. could it be frozen and if so whats the best way to thaw it out as i dont have a garage.
· Registered
Considering the age of the car the starter might just be bad. The starter on my '93 died last summer. I picked one up at the junk yard for $20, worked great. I would pull the starter and get it tested. Most places do it for free.
· Premium Member
Generally if you turn the key and hear a click the solenoid is good, that is what makes the clicking noise. If the starter start to turn over but doesn't it may be corroded connections.
· Registered
My God. Exactly same as mine.
Now sometime my car starts, sometime it doesn't, which made me wandering from being happy and being frustrated several times. Once it could start, it started quite well. Otherwise, it's like a dead junk. Relay clicks. The result always changed the other day, when temperature changed. And for several times, it was just going to started, but then, like stuck and no more sound.
So I guess my problem may be the corrosion of solenoid connections.
Ford, makes me hate & love it.
