im new on here, ,y name is jon. heres my problem, In the morning i go about 2 blocks and wnd i put the trans in park when i get ready to go again it stalls. i can get it to start again but only if the gas peddle is to the floor when i put it in drive it stalls again it does this about 5 or 6 times. when it starts back up after that its fine til the next day. what causes this, if someone knows.
First thing to do is run the complete code test (KOEO, CM, and KOER) and see if anything comes up. No tools required, as your car is EEC IV / OBDI. Jumper the EEC TEST connector and watch the CEL flash out codes. Instructions here and all over the web on how to do this.
Sounds like the iac (idle air control) is acting up. Silver cannister that sits atop the intake near the throttle body. Might remove and clean with intake spray cleaner.
no codes pop up. ill try the iac cleaning idea and see if that works
