Squeeking Front Suspension
944 Views 2 Replies 2 Participants Last post by  jason8225
Alrighty, well apparently I'm getting a definite squeek from the from suspension while going over bumps. I even rolled down the front windows and turned the engine off as I went over a speed bump and it sounds like it's coming from the right side. As some of you know, I had an accident a few years ago when I took the car over a curb due to understeer and pretty much ripped out the front suspension. Both lower control arms, both front struts, and 1 outer tie rod (on the right had side). However the initial impact was with the left wheel, which subsequently took chunks out of that rim.
But this happened at about 12,000 miles and I'm at 38xxx now but the rears are just fine. What do you guys think?
-mobiuslogic
EDIT: Pictures from the accident
When I had squeaking in the front suspension on my '96 I replaced the outer tie rods and that fixed it.
G
I have a squeak but have been ignoring it for a while. <_<
