1 - 11 of 11 Posts
G
I have just noticed when I turn the wheel I get a squeak from the drivers side front fender well.
what could this be? and how much to fix?
I had the same problem about a year ago. In my case it was a bad outer tie-rod end. Mine cost about $200 to fix for parts and labor.
Edit: I got both replaced...so $200 for both.
It was the tie-rod ends for me too. But it wasn't the end making the noise, it was the brake rotor shield. The rod-end made it vibrate.
I replaced them myself for about $80, with an alignment included afterwards.
The other reason for a squeak can be a bad strut bearing. Not an expensive part, but the strut needs to be pulled and disassembled to change it. Usually not worht doing unless you are putting in new struts, and change the strut bearings and strut mounts while you are at it.
More annoying than anything.
mine did the same thing. bad tie rod. if you have a half an hour and $20, you can do it yourself. not that complicated.
you can check before you take it off by just grabbing the outer tie rod itself and twisting the **** out of it. if you can get it to move a little, and it squeaks...there's your trouble.
hit your local library (for a Chilton's) or look here for instructions on how to remove and reinstall a tie rod. not hard.
also, when/if you do...you'll need to get a new alignment done. that's around $30 for the front end.
good luck.
also...if you let it go...it might not break at all...but if it is a tie rod and it does break, you're gonna have a whole lotta fun steering.
1 - 11 of 11 Posts
