1 - 20 of 24 Posts
It sounds pissed off. lol
Same set up I have on my Sentra BTW. Definitely sounds wimpy compared to that.
:blink: :thumb:
Bad ###### Ass
Edit: Ninja Edit to compensate for lack of sleep...
Edit2: Screw it, pics are good, even for reposting.
:worthlesswithoutpics[1]:
Coming right up!
Custom 3" To MAFS Adaptor
Fabricated from Sheet Steel, Aquarium sealant and some good old fashioned engineering!
Wow... looks clean! With the wheel well liner ya think it'll still be ok? No water intrusion?
Haven't had any yet :thumb:
:x: AEM Bypass will be installed by the flood season. :p
sounds nice!!
<div class='quotemain'>
:x: AEM Bypass will be installed by the flood season. :p [/b][/quote]
I heard that it robs power since it spits air out the side. Any truth to that?
Discussion Starter #10
sounds nice!!
so how much you end up payin for this whole setup?
Spectre 3" Aluminum Tube: 39.99
Spectre 60 Degree Elbow: 10.99
Spectre 3" Air Filter: 19.99
Spectre 3" Adaptor: 5.99
Sheet Steel: 4.99
Aquarium Sealant: 4.49
Total: $86.44
<div class='quotemain'> <div class='quotemain'>
Never heard of that, if its properly installed (Parallel to the throttlebody) then it shouldnt do that. :dunno:
sounds nice!!
Sheet Steel: 4.99
Total: $86.44
How would it spit air out the side? The engine is pulling the air it needs in through the intake...the intake isn't forcing any more air in. It's not forced induction. The filter, as long as it's not waterlogged, will be the path of least resistance for the engine to draw air through, so that's where it's going to come from.
think this would fit in a duratec with the battery in the stock position?[/b]
Sure. You can see his battery terminals there, so he still has the battery in the original location. There's essentially the same clearance for the intake on a Vulcan or a 'tec, so you'll be fine. :)
They all need to stay. Leave everything from the MAF to the throttle body alone...check Mediarocker's pics and you'll see. The MAF housing unbolts from the airbox, and you bolt on an adapter that will mate to the new intake piping.
There will be next to zero power gain, but it'll sound neat :)
theres actually some kind of sensor inside my airbox itself
Can you get a picture?
Discussion Starter #18
I think hes talking about the MAFS.
And yep, the battery in the normal position.
sorry got the mssg too late its dark here but its about an inch long sensor that goes through the lid of the intake box..
Sniper, that's the Intake Air Temperature sensor you're referring to. Drill a hole in the new intake, and stick the sensor in there. Ideally, you should use a rubber grommet to stick the sensor into, so that it seals and seats properly.
Mr. Mediarocker, the intake sounds freakin awesome. :thumb: Sounds just like my setup.
1 - 20 of 24 Posts
