1 - 11 of 11 Posts
· Premium Member
All four are 5x7/6x8
· Premium Member
retchid freaky ford speaker sizes. grr, why must they be different than other car brands with normal sized speakers.
· Premium Member
Same reason they use the integrated oval with climate controls and factory radio in one. So you will shell out mad stacks of cash for their muddy $20/speaker "mach" system rather than install your own superior and cost effective aftermarket setup.
You can cut small rings out of 1/2" MDF that will allow you to run a 6.5" component set in the front though.
· Premium Member
5x7's & 6x8's are the same size speaker, the mounting plate is just larger in the latter though.
· Premium Member
Yes they will fit. jtkz13 is correct, they are the same size speaker with a larger mounting plate and both will fit in your car.
· Premium Member
Get 6 X 8" speakers, they sound better.
1 - 11 of 11 Posts
