1 - 20 of 61 Posts
Hey all, there seems to have been an interest in the speaker sizes for the different gens here. So for further reference here are the sizes of speakers that come with the Taurus. So I dunno if someone wants to pin this or something they can.
Gen 1 1986-1991
Front: 5.25" (some have used 6.5")
Dash: 3.5" (with Premium/JBL)
Rear: 6x9" (6x8" for the JBL I believe)
Subs: 6x8 drivers mounted under stock 6x8's
Gen 2 1992-1995
Rear (in Sedan): 5x7/6x8
Rear (in Wagon): 6.5"
Sub: 6.5"
Gen 3 1996-1999
Front: 5x7/6x8
Rear: 5x7/6x8
Tweeters: 2" w/inline crossover
Sub: 6x9 (1996 ONLY)
Gen 4 2000-2007
Front: 5x7/6x8
Rear: 5x7/6x8
Tweeters: 1" w/inline crossover
Sub: 6x9 (2000 ONLY)
It is possible to install other sizes by cutting out some adapters. I got 6x9's in my gen 3. You could put 6.5's as well. Just takes a little creativity and a bit of cutting sometimes.
Subs pertain to JBL systems. Stock and Mach systems do not have subwoofer drivers.
Thanks to everyone for your input, I have edited my post to reflect models I left out (I verified them before changing this list).
Discussion Starter · #2 ·
In 1996 JBL used a component system with a 5x7" woofer with an inline low pass filter and a 1" tweeter with an inline high pass filter. These were biamplified just like the JBL system in the SHO. In 1997 with the Mach system, Ford used a regular 5x7 and chose only to high pass the tweeters (dunno why because the imaging is bad lol).
Gen I's with premium sound also had 3.5's in the dash. I still don't know whether to order 5.25s or 6.5s for the front...anyone have experience with 6.5s in the front for a gen I?
Discussion Starter · #8 ·
Hmm... I'm really not sure.
Could someone who has the Ford service CD please check this out? Get all the wire colours for all the systems, then we can put it in the wiki.
I'll try to look this up later in my repair manual but I don't know if there's anything in there.
I would imagine that it's the same...I can't see why it would be different for the Mach, but the JBL will have the subwoofer out as well so I couldn't say for that one.
I was reading the pinned topic at the top about speaker sizes, and I would like to put 6x9's in the two rear speaker holes what do I have to do to get the 6x9's to fit?? Thanks
You can either dremel out the speaker holes to the appropriate size and top mount them, or you can just bottom mount them. I seem to remember something about the Gen IV having the tension spring for the trunk directly under the speakers, as opposed to the Gen III, where the spring is behind the speakers, so you might need to look into clearance underneath the speakers.
JR
6x9's will fit with no problem at all. ;)
Originally posted by Midnight00SE+Mar 21 2006, 09:16 PM--><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Midnight00SE @ Mar 21 2006, 09:16 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-The_Silver_Bullet@Mar 21 2006, 07:59 PM
6x9's will fit with no problem at all. ;) [/b][/quote]
I have a 2000 GenIV Sedan, will 6x9's fit without modifications?
I don't think that any gen 4's came with a sub. :)
They have the mach package that has no sub.
they will fit easily with little modification, but they won't drop in directly the easiest way is to mount them from behind the rear deck panel. as others have warned you may need to pay attention to where the springs are that hold up the trunk for clearance. you will have to drill new holes and use new screws to hold them in place. does anyone have a picture of a 6x9 install from the rear they could post?
to install them from the front you will have to cut the speaker slot larger, that's a bit trickier of an installation.
The best way is to get a standard 6X8 (or 5X7) to 6X9 adapter.
Also the first post is wrong regarding the Mach tweeter size. It's 2" not 1" and has a 2" depth ;)
The problem with an adapter is that the carpet covering the rear parcel shelf will not allow for top mounting a taller speaker. Really, the only ways to do it are to bottom mount it, or dremel the holes out.
JR
That was the case with the older adapters. The newer ones are usually only around an inch thick, but since you don't top mount when using an adapter it's not really an issue ;)
It would be easier to just dremel the parcel cover a little bit or add a XTC cover to it :)
:blink:
what kind of adapters are you talkin about? most of the ones i have seen are made from 1/8" plastic
Could do like i did :ph34r:
1 - 20 of 61 Posts
