I'm a n00b to the forums, but sold parts for about 6 years. I keep reading posts about plugs and which ones to use. I just wanted to let everyone know that Autolite makes Motorcraft plugs and ergo, they are one in the same. They are stamped differently but created identically in every other way. I hope this saves you some $$$ at the parts store where the kid behind the counter tries to sell you the Bosch +4's since it's the highest price he can find. Research: http://www.autolite.com/products/index.html.
Most of the people here have tried to shy away from using Bosch plugs beacuse of high failure rates. I think most people are using Autolite/Motorcraft plugs in their Tauri.
JR
PS- Welcome to the club!
Thanks. I just didn't want members wasting time and/or $$$ on Motorcraft if identical Autolite plug as available, or vice versa. I know AutoZone sells both and Motorcraft are a few cents higher I believe.
if you use bosh paltinum regular not +2 +4 there is no problem with them
but im still concerned and ill will check up something since a couple of day ago i started having some weig noise coming from my engine
so ill check those and if they are weird ill come here and say so
:crybabysmiley:
Originally posted by silvapain@Jul 9 2004, 08:32 PM
I use NGK TR6. They are copper and one heat range colder than stock. But I have used Bosch DP's as well as motorcraft copper plugs, and they have all been good.
I used to always run cooler plugs on hotrods but I have wondered about what the computer would think of a cooler range plug. I may try that on my next change.
Mike
B)
my coil add lime and rust on the contact lollllllll now running better but will check plug in the morning lolllllllllllll gnight
Originally posted by mwt+Jul 10 2004, 04:26 AM--><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (mwt @ Jul 10 2004, 04:26 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-silvapain@Jul 9 2004, 08:32 PM
Mike
B) [/b][/quote]
Alberto suggested I use them when I had my EEC reflashed. For the Vulcans I'm sure it will help prevent detonation alot. I also put in a 180F thermostat to prevent detonation.
The plug fires just like normal, so the EEC won't know the difference. The colder plugs just have a longer heat sink around the electrode. Copper plugs don't last as long as DP's, but they conduct electricity much better.
