So today I dove in to replace the PCV valve and plugs, I was doing this because it had a erratic idle that would happen intermittently and was idling high. So a new Motorcraft PCV valve, new tube and rubbers, new Autolite spark plugs gaped to .050. Replaced the intake gaskets and a new EGR gasket. Started up and idled like it should of, took for a test drive, had a misfire and flashed the check engine light under heavy load but was ok under cruise conditions, returned home and shut it off to check for loose spark plug wires. Once I went to restart it it would catch then immediately die, only way it will run is if you throttle it once it fires but it doesn't run well, misfires, pops and chugs but will die it llf you let off the gas. I pulled code P0171 and P0174 but that could be from before this happened. Anyone have a clue as to what has gone wrong? Seems odd that it was fine then suddenly this happened.
