Y
Guest
I took her car to autozone and got the code 327, something for the EGR, I am wondering how hard it is to clean and or replace
--1995 Green Taurus GL 3.0 vulcan 110,000 miles
S
Guest
Discussion Starter #2
No not at all. Use some carb cleaner, and a shop towelette. That should do the trick. Also, the EGR Valve is the Spaceship looking thing that connects to the intake Manifold. Good Luck
Sal
Y
Guest
thanks, I will have to let her take my car on monday so I can fix hers. :unsure:
I let her drive it today because I was waxing hers... she came around the corner with the stereo blasting :eek: and she chirped the tires when she was leaving the neighborhood.. lol shes just not use to the TEC :lol2:
There is a small vacuum line on top. Pull it off.
There is a line connecting to the EGR. It may be a pain to remove, as it gets rusty.
YOu *may* need a line wrench to get it off, depending on how tight it is.
Last, remove two small bolts holding the EGR to the air intake.
I have the same vehicle as the one you are working on. So use this pic if you do not know exactly where it is.
As SAL said, it is the spaceship looing thing. Watch out for aliens coming out of it.
:05: (Sorry Sal, couldn't resist :))
