Engine light is on. I got these two codes. What is the cause?
J jcg2000 · Registered Joined May 11, 2006 · 59 Posts Discussion Starter · #1 · Nov 20, 2010 Only show this user Engine light is on. I got these two codes. What is the cause?
S sheila · Registered Joined Dec 24, 2006 · 23,818 Posts #2 · Nov 20, 2010 Only show this user Those are maf and iat sensor circuitry codes. Check both and air filter.
J jcg2000 · Registered Joined May 11, 2006 · 59 Posts Discussion Starter · #3 · Nov 20, 2010 Only show this user Problem resolved. Engine service light is off. It turned out that the harness connected to the mass air flow sensor is unplugged.
S sheila · Registered Joined Dec 24, 2006 · 23,818 Posts #4 · Nov 21, 2010 Only show this user Same harness for iat. Makes sense. Glad you had an easy fix.
J Jeff K · Super Moderator Joined Feb 12, 2007 · 8,863 Posts #5 · Nov 21, 2010 Only show this user I am wondering how the MAF/IAT connector got disconnected in the fisrt place. They usually dont just fall off for no reason.
S sheila · Registered Joined Dec 24, 2006 · 23,818 Posts #6 · Nov 21, 2010 Only show this user Im guessing removed for some service of some sort and neglected to be reconnected?
