OK, I've read too much conflicting information regarding which fluid I should use in my 1997 Sable (3.0 DOHC Duratec).
Mercon III or Mercon V ????
See, the thing is, is I got it flushed using one of those high-pressure backflush things... with Mercon III.
100 miles later, it's leaking transmission fluid.
I've heard that using the wrong fluid can cause leaks...
Any ideas guys???
i hvae a 97 taurus duratec....everybody says mercon v...but III is whats called for in the manual. i was told the only difference is mercon V is full synthetic...if you have high mileage on your car it really shouldn't make that much of a difference.
good luck.
