Car is a 2000 DOHC w/AX4N, 141,400 miles...factory trans/TC w/aftermarket cooler. This issue happens with or w/o the tune loaded, after I let the car relearn itself)
In the past month, I have noticed that just with general cruising...from a stop that there seems to be a bit of a delay after 4th gear engages but before the torque converter locks up. It used to go into 4th, then after a second or two the TC will lock up. Now, it's taking ~3-5 seconds, and it goes into it very "casually". However if I'm giving it a good amount of throttle, it behaves a bit better.
I have also noticed that if I'm cruising in 4th around 45 or greater, then give it enough throttle so it goes down 1 gear...it'll downshift (RPM increase), then the RPMs decrease like something is locking, then the RPMs increase (like something is unlocking).
I can goose it going up a hill...don't feel any slippage and holds gears just fine. I would also go to say that it shifts better and locks the TC up sooner like it used to.
When is the last time you had the fluid changed?
23k miles, living in the south, with an aging trans. Could be due for another change. The last time mine acted up, I only had 20k on the fluid. 'Course, I found out that it wasn't actually mercon V, so that was probably a big contributor. Regardless, I change mine every 15k now.
QUOTE (FFVulcanPowah @ May 23 2010, 05:58 PM) index.php?act=findpost&pid=806338
23k miles, living in the south, with an aging trans. Could be due for another change. The last time mine acted up, I only had 20k on the fluid. 'Course, I found out that it wasn't actually mercon V, so that was probably a big contributor. Regardless, I change mine every 15k now.[/b]
Shoot that had escaped my mind. Wow, it probably is about due. When I get back from my trip, it sounds like I'll need to budget out for a TCCA fluid exchange.
Watching the trans temp gauge, I have yet to see the car top over 200F.
Be careful in avoiding sitting in slow traffic, it raised my Trans temp to 240 degrees per Trans temp gauge reading within 25 minutes. The fluid(none-synthetic) smalled a bit funny afterwards. and it was only 9000 miles old, I guess I am due for another change as well.
QUOTE (Bull Geek @ May 23 2010, 07:16 PM) index.php?act=findpost&pid=806358
