· Registered
So, my 00 Taurus needs new pads and rotors (one of the rotors is warped, judging from wobble I get on steering wheel when braking hard).
Here is my question. Tirerack.com has Brembo brake rotos and Powerslot rotors.
Should I go with plain undrilled/unslotted Brembo's Replacement Brembo- $44 each - link or should I go get generic OEM spec stuff from AutoZone.
Also, should I stick with Motorcraft brake pads (where can I get them besides the stealership?) or is it OK to buy OEM compound pads from tirerack.com (Satisfied Pro Perform OEM Pads) Link to the pads
· Premium Member
Just go with the generic rotors, they are 20 bucks or so at autozone.
The pads are another story. On my 2000 I have performance friction semi metallic pads from autozone. They work great, better than OEM.
-Damon
· Registered
In three years and 40k with my '01 SE, I went through four sets of rotors; OEM and Brembo OEM replacements. All performed about the same. I have been pretty satisfied with the performance of a set of ceramic pads. Great wear, good feel and very little dust. The only thing I noticed was that the pads take a little longer to seat after you resurface the rotor; light squeaking.
Good luck.
