1 - 20 of 20 Posts
Hi all,
i have Vulcan with SHO's pan...but i think it is not only the text on the pan "SHO"...the previuos owner of my car says that he've changed the tranmission to SHO's transmisson (for vulcan) Where is the distinctions? I know that pan of SHO's transmission is bigger than standard pan...Transmission - AX4N
I dunno if that's possible. not that it won't mount or anything like that, I've got an SHO tranny in mine. Thing is, your info says you have a 97, that means it's OBDII , the SHO trans would have had to come from a GenII which is OBDI and most likely would not function correctly. But since I'm not totally positive, let's hope Paul sees this and enlightens us.
Yes, the question is...maybe it's only the pan from SHO for increasing the space for ATF? (as SHO's transmission must have good cooling)
From the factory the SHO didn't have any "extra" cooling that I'm aware of than any other Taurus. Some models got a very small external cooler, some didn't, that was across the board, not just SHOs. It IS a very good idea, and probably the number one most recommended modification to ANY Taurus though.
The Gen 2 ATX SHO had a beefy external tranny cooler; other than that, no special cooling for the SHO trannies.
The Gen 3 SHO has the same transmission fluid capacity as the SLOs with the AX4N. The AX4S actually has a higher capacity than the AX4N.
Chances are, an SHO pan made it onto your ax4n. AFAIK, an SHO ax4n won't bolt up to a vulcan. I believe I read that the ax4n's that were on the vulcans had the vulcan bolt pattern.
She got panned! :noes:
V8 SHO and Duratec use the same bolt pattern for the AX4N. It will not mate to a Vulcan.
... and if vulcan bellhousing = essex bellhousing, I think my plan to bolt up to a SHO AX4N just got crushed
I don't think the Vulcan trans will fit the Essex either. Believe it or not, in 25 years of fixing cars I've never done anything to a 3.8 Taurus, wow. So, I could be wrong.
The vulcan housings are the same as the essex housings. The MTX-IV that fits up to the v6 SHO, that fits the vulcan, also fits the essex. Sorry DMX. :(
so your saying with that logic, a AX4N from a G2 SHO can mate up to my Essex in place of the AXOD-E?
<div class='quotemain'>
so your saying with that logic, a AX4N from a G2 SHO can mate up to my Essex in place of the AXOD-E? [/b][/quote]
Yes.
We need to clarify this...
Gen 2 SHO ATX = Vulcan bolt pattern
Gen 3 SHO ATX = Duratec bolt pattern
G2 SHO = ax4s.
ya i had a vulcan on my 95 taurus and when my tranny died i got an AX4N-SHO tranny for it, but the best part was that it was completely rebuilt and i got it for.....$300! gotta love it
So wait, I can't bolt up an AX4N to my Vulcan from a Duratec when my AX4S quits (which, it probably will eventually no matter what I do)? Or do I have to source out a AX4N that got fit to a Vulcan at the factory.
Not only do you need to source a vulcan AX4n, you need the PCM from that car too.
Discussion Starter #20
Wow, great discussion)))
Mu friends form taurus-club in Russia says that AX4N can be complected by SHO's pan...it's not manufacture's complection but...
Transmisson for vulcan has other fastening to engine that transmission on Duratec. But Ax4n SHO pan has the same bolts that Ax4n fo vulcan...as i understand...
The previus owner of my car has burned original Ax4n transmissoin and change it to ax4n with SHO's pan...for additional capacity of oil...
1 - 20 of 20 Posts
