How I removed my PS pump without alternator and bracket removal.
Used the Lisle #39000 tool with my Vise-Grip chain clamp, this allowed me to remove the pulley without removing all the other accessories.
Be sure to spray some penetrating solvent into the hub, don't heat the hub as the pulley is plastic.
Once the pulley starts to move off, you can switch to a ratcheting box wrench.
If you have a pipe wrench you can use that instead of the Vise-Grip.
Second way to do the pump removal if you need it done faster, just break the pump pulley with a pry bar,
it is plastic with metal hub. Easy to remove the p/s pump after draining it.
I did this to remove and replace the a/c compressor and install the new p/s pump with metal pulley from RockAuto $10.
Here is the return hose from the p/s cooler that runs to the p/s pump with hose clamp on vulcan engine. 1999 not showing up anymore but 2000 shows up.
216511
