1 - 9 of 9 Posts
Hi all,
I have a 1990 Taurus SHO with a 5 speed floor shift. The bottom end of the shift lever has a ball that fits into a plastic socket mounted at the end of a rod. This rod is about, hmmm, 8 inches long? It connects to a cable that goes to the transmission. The plastic socket broke, the ball popped out, and I can't shift. I acquired a parts vehicle and removed the top part of the console, removed the shift lever from the little plastic socket, and now I'm stuck. I don't know if the plastic end of the rod is removable, or if I have to remove the other end of the rod from the housing in which it connects to the cable. I can't figure out how to remove either end! Anyone know anything about this???
Thanks,
Jim
What year is your parts car and does it have a rod or cable shifter? I would go to the rod shifter if you can.
I am not sure about taking apart the shifter but I would ask on SHOForum.
Both cars are 1990 SHO'S and both have cable shift mechanisms, but there is a short rod that links the gearshift lever with the cable. I'm looking to find out how to disassemble the rod/cable assembly. Thanks.
<div class='quotemain'>
My 91 originally had a cable shifter, this was a few years ago so I'm working on old memories here....
On mine, the plastic socket that the ball fit into on the linkage cracked and would no longer hold the ball in place, which rendered the shift mechanism useless. I secured mine with a couple of zip ties and it held really well. I eventually upgraded to the rod shifter, because I never felt fully safe with this setup.
You really should look around for a rod shifter, these day's they're going for under a hundred bucks and it's one of the best upgrades you can do for driveability.
Sorry I never had a cable shifter, I would try SHOForum.
If you have to fix the linkage, try this. Go to a parts store and get a closed battery terminal end with the two screws that would normally tighten to the cable. Take the plastic off the rod end exposing a threaded end. Put the end of the rod into the cable clamps. The cable clamps will have ridges on it that will fit into the threads on the rod. Tighten that down. Put screw through the shift linkage and through the battery cable hole. Make sure you have washers at every opening. Should last a while.
Hi all,
Thanks,
Jim
Sorry, I posted my reply in the wrong place. Look down to the reply from texasbrowns. I think it will solve your dilemma. Sorry.
I have a fix for that bad socket and you don't have to do a whole lot to repair your shift problem.
I had the same thing happen to my 1989 SHO 5-Speed. Couldn't find new or good used shift cables. I noticed my cables were really pretty good shape except for the ball sockets on the shifter end of the cables (center counsole).
So I designed a new ball socket that is literally a snap in piece. I had some made at a machine shop, then checked them with a caliper to make sure they were to the drawing.
The material is either a machineable nylon or Delrin.
Attached is a copy of the drawing I used. This part, if made to the drawing (which is in mm's), does work. I used it on my SHO for the last 30K miles before selling it.
This part will tighten up the shift linkage and make shifting more positive. I really liked it and had zero problems with it.
I have a 1990 ford taurus sho with a 5 speed and I cant figure out why the shifter has so much play in it even when it's in gear I thought it was a bushing but the bushing seems to be fine and so I checked the linkage and it was fine as well I'm completely stuck I've never had this problem with a shifter need some help cuz it's my daily driver and I have n oi back up
1 - 9 of 9 Posts
