Don't see why it wouldn't 'fit', nothing changed in the interior in that department between the GL and SHO. However wiring it up and getting it to actually function will be a completely different story.
What are you going for? Is it something a simple set of gauge faces from SHOSource would fix?
However now that I check, the gauge faces are gone. What's going on, loudsho?
i want the higher speedo and tach,
a sharpie can make that happen. no really though. the cluster will fit. the tach might not work correctly. it might stumble a little because its missing 2 pluses from the v8 to the v6. i would get a 99 sho cluster. its a little nicer imo
All gen 3 clusters are totally interchangeable, just plug and play. I changed mine to a '99 cluster from a duratec, cuz I wanted the 120 mph instead of the 110, plus I liked the looks of it better.
I would recommend, though that you change the odometer setting to read what you have now. There is a how to in the topic finder above.
