Here is the latest installment in the continuing saga of the deterioration of my bull...
My 98SE has been experiencing intermittent shift-interlock problems... that is, even with the brake pedal depressed, the car will not shift out of park. Sometimes it does, and sometimes it doesn't. Sometimes, when it will not shift out of park, if I rock the car forward, the car will shift out of park. Today, I have not been able to get it out of park at all. When I checked for operation of the brake lights, I found that they don't work, either.
So, I immediately suspected the BOO switch, and picked up a Motorcraft-branded replacement at my local parts store for $10.50 + tax. In 5 minutes, I had the switch replaced. However, this has not fixed the problem(s).
I've fooled with the harness to check it for opens/shorts, and it doesn't seem to have any problems (I made sure that there was good contact inside the harness and wiggled the wires around to make sure I didn't have an intermittent open). I checked all the pertinent fuses (stop lights, shift lock, etc.), and they were all in good shape. Now I'm out of ideas.
The weird thing is that this started happening with more regularity after I got the car back from having a front-end alignment. It hadn't had these problems for a long time, but over the last two or so weeks, I've been dealing with this more and more until today, when I've had no sucess in shifting the car out of park.
If anyone could direct me to some other things to check or point out where I've gone wrong during diagnosis and replacement of the switch, I'd appreciate it.
Many thanks in advance,
Sean
Sean
