DTC P0411/P1411 indicates Secondary Air not detected. In order to test the pump, it must be capable of driving the HO2S lean.
NOTE:
Some applications have one or two AIR diverter valves.
Possible causes:
-- Electric AIR pump fault.
-- Hose from electric AIR pump blocked.
-- Hose from electric AIR pump leak.
-- AIR bypass solenoid stuck open/closed.
-- AIR bypass solenoid leak/blocked.
l Visually inspect electric AIR pump hoses from the electric AIR pump to the AIR diverter valves.
l Inspect air hose for cracks, binding, obstructions, water or ice.
This is a cut and paste from the service CD. I have the same code from time to time, in my case the hard line from the front manifold to the diverter valve is broken. It didn't affect the way the car ran, so I haven't gotten around to fixing it yet.
