I had a code show up on my scanner that I have never seen before, nor can I find it in any search. It is "U0BCB". Has anyone seen that before, or did I read it completely wrong? It got it when the P0401 code showed up,(fixing that next week) and I went to clear it.
Thanks for any help or info anyone can give me.
Welcome to TCCA.
"U" codes are a "Network" code.
What did you do to your scanner????
"E" mail the scanner manufacturer & ask them what specifically it's for.
Was the "U" code found with the Scangauge????
If so, it sounds like a connectivity problem with the Scangauge ll.
Did you have a CEL lit???? If not, the P0401 may be a bogus code, especially with the "U" code present.
If the CEL was lit, the P0401 code is for insufficient EGR flow & an acting out DPFE sensor, EVR, system inter connecting vacuum lines, electrical connections & lastly the EGR valve, in about that order are the usual suspects on the list.
Would be interesting to hear what you find for both.
