I have a 2000 sable with a 3.0 24v duratec motor that runs great in the spring , summer and fall.
When winter comes it runs really rough in the morning until it warms up. No check engine light and
i have replaced the temp sending unit,map air sensor, iac control, fuel filter,.
I've run injector cleaner through it and checked for vacuum leaks and check fuel pressure.
Took it to a mechanic and of course it did not do it that morning and he told me no check engine he
could not help me.
could not help me.
Spark plugs have been changed ,coils have been checked, can't find any vacuum leaks.
It's just happens in the winter mornings and not every winter morning.
On the times when it runs rough, was the car moved like 20 feet, ie over in the driveway? My dads sebring would run like **** if you moved it out of the way in the winter without getting it up to temperature.
I have the same problem with my 2000 24V. I replaced the upper intake manifold seals and ETC sensor this weekend and still have the same problem. I'll be following this thread.
Tom
