· Registered
Hi, I could really use some help and see you have written about this subject before.
I’m in need of new front upper subframe bushings, the lowers are ok for now.
Can’t find anywhere, but have the new bolt from Ford that goes thru the center of bushing on each side.
They are not the front lower with the four studs.
One existing partial broken old bolt is stuck in the car and has to be removed somehow. Any ideas on that too. I guess I need the nut retainer on top of frame still, so not sure I can drill or punch-out. I believe frame may be boxed with lack of access to nut. Thanks to all!
Motor vehicle Bumper Automotive tire Automotive exterior Gas
Automotive tire Hood Automotive lighting Motor vehicle Automotive design
