1 - 10 of 10 Posts
· Registered
OK..Dash lights wont come on so I look and find out the running lights arent on either. I thought this might me a safety feature (as in HEY..your running lights arent on so we will make the dash lights not work so you notice it) so I checked my mini fuses under dash..nothing so I pulled ALL of them, all good. I also checked the fuses under the hood..all good. Then I pulled the bulbs in the back..they are all good. My break lights work, my headlights work (did I mention my daytime lamps and auto lamps at night havent worked for some time?) but no running lamps front or back. We pulled the switch out to look at it..there are 2 plug ins..one for switch and one for dash dimmer switch..you have to have the dimmer switch pluged in to get the headlights to work, that seemed odd. With the headlight switch unpluged the socket shows voltage..plug it in and it doesnt show any voltage. PLEASE help me!! Thanks in advance fellas! :notworthy:
· Premium Member
I would guess the headlight switch is bad. I know one time I was about to go out to drive at night and I turned on my parking lights and they didn't light up and in the headlight position, only the headlights were illuminated. Turns out the harness was loose from the time I took the dash apart to put the new speedo in.
· Premium Member
Daytime running lights...they're on all the time...stupid safety feature.
It's basically a headlight that runs at a lower wattage so that oncoming traffic can see you better. They turn on as soon as the car is started.
· Registered
Running lamps are the lights that are on when your headlights are on..not DAYTIME lamps. As in the lights that light up from behind at night and the 2 amber round lights up front. Well went to a junkyard and got a new switch..and the headlight still turns on but no running lights still..is there a realay that could be bad. I am 5 hours away from my books so I cant look there, figgured someone here might have an answer. So again..running lights wont come on, headlights work fine, brake lights work fine, not a fuse, signals work..not switch or fuse..HELP a brother out!! :chili: :banana: :notworthy:
· Premium Member
Those are parking lights. It's the first "click" of the headlight switch before the headlights.
Yeah, it could be the relay or the wiring harness. I have no clue where the relay is.
· Registered
Who the hell would call them PARKING lights..why would you turn lights on when you park? We have been calling them running lights for 30 years..as do every mechanic I know..so we will continue to use that term! :D But I will look for the relay..dont know where it is but I will keep looking!
· Registered
hehehe...they call them parking lights in Australia.....but then again we have foot paths, car parks, and mobile phones. We even have nature strips and softdrink. I have no idea what a pager or a two way is, and till recently I had no idea what pop (softdrink) was.
Anyways good luck fixing your parking lights
Julian
1 - 10 of 10 Posts
