First off - if this was posted with the same symptoms I apoligize...
'96 3.0L 111,135 Miles. P&P upper intake, Gutted MAF, cone fileter...
Im constantly getting a running lean code p0171/0174 IIRC, which is running lean front and rear banks. The code has only been thrown on normal driving conditions, I.E - not flooring it or revving it up constantly. Now, I have replaced almost every gasket on the upper part of the motor and double, even triple checked the torque specs. The gutted MAF and intake setup have not given me any problems up until ~ 8 months or so ago when I first got the code. Ive had the P&P/MAF/Intake setup for approx 2 years prior to this code with NO problems...The only thing that is activly wrong with the engine is the IAC is going bad and it needs a serpentine belt.... Ive replaced/tested the following:
Replaced all 4 O2's
Replaced TPS
Replaced UIM Gasket
Replaced EGR Gasket
Replaced PCV Valve
Replaced in line Fuel filter
Tested Fuel pressure at shrader, KOEO, KOER everything in normal spec, incl. FPR
Checked all vac lines to intake and sensor connecotrs
Ive run many bottles of FI cleaner through the system
The only thing that I can see going wrong is the MAF sensor is failing, but on a eec-v/obd-II system that would throw a "MAF out of range" or equivilant code right?
I do have a spare MAF/sensor and intake hose that I will be swapping out soon to see if this will remedy the problem. Does anyone else have any imput concerning what else to look at? Im pretty much stumped, and the maf swap is the only thing that I have left up my sleeve of tricks.
Replaced all 4 O2's
Replaced TPS
Replaced UIM Gasket
Replaced EGR Gasket
Replaced PCV Valve
