naturally your rpm's will go up when you drop it into neutral, because the engine meets no resistance with the transmission. Now do the RPM's drop when you slow down while in neutral or is the car still in gear when you deaccelerate?
That's right, both of our Bulls do it to. 2 hours of diagnostic work at the DEALERSHIP for something that they should know is normal behavior??? Hope you didn't have to pay anything.Originally posted by SixFoFalcon@May 18 2004, 12:03 PM
What you are describing is NORMAL, programmed behavior. The rpms will hover there until you put the car back in gear or slow down. This is so that there is no jerking of the engine and drivetrain when you put it back in gear. I'm not sure what year this was implemented, but it IS intentional.
And I think the tech is full of :bs:. If that was the case, it would be much more obvious when your tank is on "E". The fuel pump uses the gas in the tank as a coolant. Ambient temps make little if any difference to the pump.Originally posted by gruffybear@May 19 2004, 04:10 PM
Tech thinks it may be fuel pump heating up in tank and starting to break down (especially since it only happens when it's hot outside) but he couldn't get it to act up or shot a trouble code.
