1 - 20 of 24 Posts
sending in for new title, i lost the one i had,, i hate to just scrap this car only needs a drivetrain , and some TLC things done ,,,,, i shoud get around 600. for scrap for it . first 600. take it , paper work for title gos out tomorrow, takes about 5 to 7 days to get back, then to the bone yard it will go if someone here do get it 1st,,,,,
one of 57,,, rose mist ,, no bits ,
How about 2 $300 payments? Have to price transport to Rochester, NY also....
I hope this gets saved. It's one of only 58 Rose Mist 1996 SHO's ever built.
Is anybody familiar with the differences between a Tec AX4N and a SHO AX4N? I think I read the bell-housing bolt pattern is the same. Old Blue has terminal rust (subframe point of attachment to body corrosion, see JW's post on subject) but the drive train (engine & transaxle) is mint.
Besides the lack of a VSS, different final drive ratio, higher stall torque converter and some differences in the valve bodies, that is all I can remember. Bell housing is the same.
Ah the blue bucket is rotting? Good time to swap, you'll get your Rosemist...
Also keep in mind the V8 SHO uses the ABS system to determine vehicle speed, slight difference from the SLO.
i bleave it 57 made, you can send the vin into ford and they will send yoou a cert. on the car
It was 58, I've seen the certificate from one of the other ones.
Glad someone is able to save this SHO...I hate to see them in junkyards. I do believe someday that they all will be valuable in some way.
Discussion Starter · #16 ·
should have the title back from penn.dot by friday..no bites yet,, i hate to scrap it but i cant keep it
i will take payments,,, if u want pics of it i can text them to you... ,
Discussion Starter · #17 ·
looks like no bites,,,, dam shame i cant keep it and fix my self,, if i could i would,, guess im gona load it up in the the morring,pull wheels, cats off it, and ship it to the bone yard,,
Too bad.... there's a huge u pull it yard in Hazleton that I'm sure you'd be able to get a motor/trans for it.
1 - 20 of 24 Posts
