1 - 20 of 20 Posts
This is what happens when you paint your rims the way you want, then your friend convinces you to do it his way, then it looks like **** and you do it your way again.
My way
His way
My "new way"
Edit: Also painted the calipers Ford Racing Blue
erm... it didn't work... TCCA uses the coding with the square brackets, not the >< ones.
Ultimate HTM-Fail. Use the [ img ] [/ img ] (no spaces between the word and the letters) tags, with the image's URL between the tags. :)
Looks pretty bad all three ways. As far as the outcome, if you like the black steelie look that's what counts. I know those aren't steel wheels but that's the look the car will have going down the road.
A note on the paint, any particular reason you painted over the weights and didn't remove them?
:( I really liked the first way.
And you're right about your friend's idea... :lol:, looks like this:
A note on the paint, any particular reason you painted over the weights and didn't remove them? [/b]
Actually, I was going to remove them but forgot to remove them. I only have two coats on as of now but will add a third coat soon
And you're right about your friend's idea... :lol: , looks like this:
Haha my thoughts exactly. I wish I could have gotten the "chrome lip" back, but its not possible
Couldn't you sand down the edges? Or are the wheels just chrome plated?
Couldn't you sand down the edges? Or are the wheels just chrome plated? [/b]
I sanded down the edges but I almost cut my tire open so I havent attempted to recently. It also put a brushed alluminum feel on it so it has a different pattern on it.
The first way was the most tolerable. Had you painted every other "petal", it probably would have looked pretty cool.
Take those tires off sandblast them and get them powdercoated black...
Otherwise the first way looked best.
:puke:
But if you like it, thats all that matters.
There are times when you shouldn't listen to your friends - this was one of them. The first design had potential. I'm not fond of the end result, I'd strip 'em and start over.
:puke:
Be careful powdercoating aluminum wheels. I've seen several that have been powdercoated crack, and eventually fail because they became brittle. Notice that all wheels from the factory that have a "color" (usually silver) are painted. A professionally done paint job makes them look quite good. Rattle can jobs usually look like cheap ass.
Discussion Starter #17
<div class='quotemain'>
:puke:
Be careful powdercoating aluminum wheels. I've seen several that have been powdercoated crack, and eventually fail because they became brittle. Notice that all wheels from the factory that have a "color" (usually silver) are painted. A professionally done paint job makes them look quite good. Rattle can jobs usually look like cheap ass. [/b][/quote]
Yea, I'm not looking to spend that much money though.
1 - 20 of 20 Posts
