So, my 98 SE (130kmiles) has been eating right-rear tires for the past three years. Each time I've had it into the shop, I've had no problems reported. Recently, after having the transmission serviced and the front ball joints replaced , I took the car to a tires/alignment shop that's worked on my car before (the alignment was under warranty).
They advised me that my right-rear wheel camber is at -2.4 degrees, that it is out-of-spec, and that it's due to either a "bent knuckle" or a "problem with the strut". The mechanic couldn't tell me which it was when i asked. This seems a little crazy to me. According to them, the knuckle is a dealer-order part, and costs $89.99. They said that they would install it without labor charges because they should have caught that before.
So, I called up Autozone to inquire about the price of the knuckle, and they had no clue what I was talking about. If there are knuckles in the rear, do they also have a different name? From the posts here, it seems that the front knuckles are what the wheel bearings are pressed into. In the rear, are the knuckle analogous (i.e., the wheel bearings are bolted to them)?
It just seems like all of this is very fishy. I just replaced the rear wheel bearings a year-and-a-half ago. I know that something could break in that time, but the tire wear issue never improved after I replaced them. I still get a "wumwumwumwum" sound after about 6 months of driving.
Thoughts?
Many thanks in advance,
Sean Douglas
Norman, OK
[email protected]
Thoughts?
Sean Douglas
Norman, OK
[email protected]
