Muriatic acid.
Do this OUTSIDE. Don't even think about doing this inside. Outside with a fan is better. It makes chlorine gas.
Remove the tank. Plug the tube fittings with plastic and tie wraps. Fill it with a 50/50 mixture of that muriatic acid you've got left over from cleaning the driveway. Don't but the cap on. Let it sit for at least an hour.
Hold it downwind, hold your breath, and dump out the rust and hideous yellow colored liquid. Use goggles and rubber gloves like you would use regularly handling muriatic acid. It won't take away the yellowing from age, but you'll be able to see the fluid level again. Use Amorall or silicone spray to make it look good and be more transparent.
