Hello All, New here. I am trying to replace the lug nut studs on a 2002 Ford Taurus driver front. I know you have to turn the wheel to a certain spot to get the studs out.
Here is the problem, with both front wheels jacked up off the ground and the transmission in neutral the driver side tire will not turn.
That means you wouldn't be able to push the car with trans in N and side brake OFF. It doesn't make sense. Try the full range of gears before leaving at N. I am equally baffled.
Maybe your shift linkage is falling apart and you're not actually in neutral?
