Sorry for so many questions...my car has behaving wonderfully until the past few months and it seems everything is starting to go bad.
We replaced the rear motor mount today. Ended up being the $60 one, but that's ok. Took just under 2 hours for husband and I to do it. And it would have been quicker, but we took out the 3 bracket bolts, and didn't realize those did not need to come off. Doh! The mount did not look shot like I thought it would have. Looks like it had been leaking and could not tell if any fluid was left in it.
Problem is...got it back together and the car still jumps back when you put it into drive. It moves a little bit when you put it in reverse, but alot when it goes into drive. And when you're driving it, anytime you gas it from a stop it thunks.
So any other ideas what could be causing this problem? I did notice a recall I never got done about some subframe mounts. Could that be causing it? I should probably get it done anyway.
What about the transmission mount? And our cars only have 2 motor mounts right? Front and rear? I don't think changing the front one would do any good.
Thanks for any help you can give me!!
