Replaced heater core in 99 se, all went rather well under 2 hours the only problem now is air only at defroster and floor no panel, is there a special way that the actuator gets installed? Damper was fine maybe I got it to tight. Nothing broke off, i was surprise how well it went.
Thanks
Ron
New water pump, tensioner, belt & core this week........
Defrost is the default air flow if there is a vacuum loss to the vacuum motors that control the mode doors. Any chance you accidently disconnected or forgot to connect the vac line going to the mode selector?
