1 - 10 of 10 Posts
· Registered
You dont list the engine you have... Vulcan or Duratec. Vulcan plug / wire change is VERY easy.... one of the easiest FWD V6 engines aroubnd to work on. For a first timer, 2 hours max. For someone who has done it a few times before, 1/2 hour. Duratec is harder due to limited access, but doable by a first timer in an afternoon.
How do I know the type, ie Vulcan? I have the 03 Taurus SE with DOHC 24 valve my engine looks nothing like what I'm seeing googling a 2003 Taurus SE
· Registered
2004 Taurus SES Duratec
24 valve is Duratec.
  • Like
Reactions: sheila
· Registered
I have changed plugs on my 2000 Taurus 3.0 DOHC with no problems. However, my 2006 with the 3.0 12 valve (Vulcan?) only got the front plugs changed. People say you can reach around and get the back plugs, but I cannot reach that far. It looks like the intake has to be removed. Can you confirm this? Is there a "how to" somewhere?
Is the #1 plug on a dratech, 2003 in the back or up front
· Registered
Yes, engine check light came on, went to Auto Zone, and it came up #1 plug and/or wire needs replacing due to misfire.
This is probably the best video on the job:
  • Like
Reactions: sheila
· Exalted Grand Poobah
Check the VIN. If the #8 character is a "U" y'all have the OHV 12V Vulcan. If not, y'all have the DOHC 24V Duratec.
1 - 10 of 10 Posts
