I have a 1998 Taurus sedan with a 3.0L vulcan motor. I hear that you can use Moog P/N: CC859 rear coil springs from a 95 on a 98 rear. I would like to stiffen up the rear it's sagging. Moog 98 rear coil spring P/N: 80093 is the part number it calls for just tring to make sure it will fit. The 80093 is a constant rate spring and the CC859 is a Variable rate spring. Or should I just get Quick Struts. I put a trailer hitch on so I can pull a 4x8 trailer with my ZR7 for the long rides. Any answers to this thread would be app.
Definitely use the CC859. They will be more up to the task. You may also want to add on some struts, like some KYBs or something.
Yup they will.
+1 on the cargo coils. Firm ride but you don't have to worry about SAS again and you can carry more than a suitcase without bottoming out!
