1 - 2 of 2 Posts
On the after market r/s there should be an (-)activation wire. Tie that wire to the horn wire on the car. Set it to a double pulse. Now everytime you hit the lock button three times on the factory keyless entry and the horn honks 2x the r/s will activate.
This should help
WIRE COLOR POLARITY LOCATION
Battery YELLOW (+) OR LT.GRN/VIO IGNITION HARNESS
Ignition 1 RED/LIGHT GREEN (+) IGNITION SWITCH HARNESS
Ignition 2 GRAY/YELLOW (+) IGNITION SWITCH HARNESS (BLOWER MOTOR)
Ignition 3 RED/BLACK (+) IGNITION SWITCH HARNESS (FOR A.C.)
Accessory 1 RED/BLACK (+) IGN.SW.HARNESS (HEAT A.C.)
Starter 1 RED/LIGHT BLUE (+) IGNITION SWITCH HARNESS
Anti-Theft Type RF ACTIVATED SYS.
Anti-Theft Descript PATS
Key Sense BLACK/PINK (-) IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING
Tachometer YELLOW/BLACK (-) MULTI COIL (TAN/YEL PASS FIREWALL PCM 48
Speed Sense GRAY/BLACK (AC) TRANSMISSION
Parking Lights BROWN (+) AT LIGHT SWITCH
Brake Lights RED/LIGHT GREEN (+) SWITCH ABOVE BRAKE PEDAL
Reverse Lights BLACK/PINK (+) AT SWITCH ON TRANSAXLE
Horn VIOLET/ORANGE (-) AT STEERING COLUMN 4 PIN PLUG"
1 - 2 of 2 Posts
