EDIT: after inspection... never mind the title! but it was interesting to see how dirty this thing was. Makes me wish there was a coolant filter on these things!
Well my new find (98 Taurus with 165k on the clock) was leaking coolant slowly near the water pump. I was probably loosing 1/8 cup when parked and who knows how much when running. Anyways, I finally tracked down the leak and it appears to be the lower intake manifold gasket on the water pump side of the engine.
When I removed the intake manifold (and the injectors and the wiring, and the valve covers, the throttle body and a few other things to get to the lower intake manifold) I found this! See pictures:
There's no way the coolant could have cycled through these heads because the passages in the intake manifold are completely plugged. I wonder if my heads are ok after this. I suppose some could have flowed in to the in side of the head and back out of the in side but not made a circle.
I'll be doing a compression check to see if my heads/gaskets are still ok after this. Hopefully all is well. If not I guess I'm this close anyways. It won't be too much harder to finish the job.
