In my 2004 SEL, the autodim mirror has a bit of vibration that isnt noticible all the time...mostly when going 75 down the freeway and I go to change lanes and the vehicles behind me are fuzzy (if I simply touch the mirror the its gone, and it isn't so bad that I cannot tell whats behind me, just bugs me is all). I have checked the mounts and all is tight, except for the where it actually goes into the body of the mirror - there is a little side to side motion.
Does anyone have any tips for tightening this thing up? I couldn't find any tightening screws of any kind back there.
Thanks in advance...
Those Gentex mirrors do vibrate pretty easily. I ended up snapping the face plate off mine, removing the mirror glass, and tightening up a bolt inside that holds the arm to the actual mirror assembly. Then put it all back together and it was better.
I hope there is another way because the face plate was vibrating too and I superglued it.....which fixed that.
:lol:
Well since it is all plastic, thats sort of the clamshell/snap together method Ford used. No other way to get inside the mirror.
You could also try to shimmy like a broken up toothpick between the mirror slide channel and the mirror mount (that is adhered to the windshield). The mirror snaps on to the windshield.
Not to sound too obnoxious here, but you could also try reducing the vibration through the car as a whole. If you haven't had the tires road force balanced, you could see if that doesn't help. Beyond that, you just have to do what has been suggested above.
That's a good idea.....I'm pretty anal about r&r on my tires but have never had the road force balancing done. May have to try it.
That's what I was thinking as soon as I read the post title, before even opening it....
