1 - 20 of 24 Posts
The wagon has a different suspension than the sedan.
Wagon has a separate shock and a separate spring. The inside of the spring is empty and can accomodate the air bag. I know because I installed these air bags on my wagon.
The sedan has a mcpherson strut in the rear with the rear spring an integral part of it. There is no room for an air bag on the inside of the spring.
Ahh very true. For some reason I was thinking the rears for the same as the front, which I know is incorrect. Well then.... hmm. My springs arn't saggy but they just cant handle the extra added weight plus 2+ passengers. Is there a stiffer spring with a higher load rating than the stock springs? Id be happy with an extra 1" tbh. Any suggestions are welcome.
My shocks and struts and coils are all healthy. Being that the Mogg coils are progressive and 194lbs compared to the stock 100lbs springs.. that seems to be a good idea. Would they mount up to the stock struts without a problem?
Yeah thats fine. Its just that my 300+lbs of speaker weight take a **** on them stock coils lol. Thanks for the info m8.
Nothing special is required. You just use gen3/4 struts and mounts with moog cargo coils for a gen 2. There's a few people that have done this on here.
Discussion Starter · #11 ·
Just found this. Very interested in pics and vids of this installation. Theres a wall in my future. So it would be good to keep in mind.
Yep, but if you do a wall, the wieght should be in the center/rear of the car anyway not all on the rear axle. Hints my problem bottoming out with 3 passangers lol. 2 subs that weight 50 each, a battery that weights 78, and ap that weights 25 and a 150-200lbs box.. lol yeah it adds up.
Forgetting the 4 78 pound batteries in the trunk are we? :0 Right over the axle. I use birch for my boxes. Single layered with double baffles. And lots of fiberglass resin and mat, and bracing. My last 2 12's box, double layered, glassed etc. Was light enough to pick up with 1 hand. When your subs weigh more than your box. You know your doing it right!
Discussion Starter · #14 ·
I used some cheapo 3/4 ply wood, wood putty'd then resin'd the inside. **** is just bulky lol. I want to remake the box using ultralight mdf. :) UL MDF is just as strong as standard mdf but 80% lighter, cuz its a different type of saw dust. I can carry a 4 x 8 sheet of it with 1 arm comfortably.
Win ^
I just performed the CC859 upgrade on my SHO. It lifted the rear nearly 2 full inches. Driving it now is a definite improvement.
The hardest part of the job was removing the upper retaining nut, as there was a lot of corrosion holding it on. Applied some nickel anti-seize during reassembly, hopefully I don't have to go back in there for a while now!
Discussion Starter · #18 ·
Here is maybe a dumb question.... what side of the spring goes up? Does the smaller spaced coils need to set at the base or the top? OH YEAH and when I read the wiki how to...... my setup isnt anywhere close to whats in the wiki page. my Gen IV doesn't have rear endlink in the rear. It doesnt even have a spot to mount them, pretty weird. Is that a Gen 4 vs Gen 4.5 change?
The tightly wrapped side goes up. I haven't seen the wiki, personally, so I can't comment. I have my taurus up in the air right now, I will take pics of the suspension setup and give you a detailed description of what order to do it all.
Discussion Starter · #20 ·
I got this all done on Monday. It was pretty easy really, especially since I work at a ford dealership haha. On my Lunch break I used our wall mounted spring compressor and fabbed it all up. While I was at it I replaced the rear struts with Monroe Matic rear struts. Man, its like a brand new car now. Ride quality has greatly increased. rides very smooth. I used to have to be very careful on dips and rail road tracks and what not. But I tested them out on Tuesday and I drop 75mph over the same tracks I usually have to slow down to 45 on. I ended up spending $140 on the set of Monroe Matic struts and $70 on the Moog Cargo Coils. SO a total of $210, All around money well spent.
1 - 20 of 24 Posts
