1 - 10 of 10 Posts
SHO Source sells those for the G1/2...I'm not sure if the rear control arm box is the same on all years, though.
It isn't. I'd beware of a one-size-fits-all treatment.
With that said, the H-braces are a great idea. I wish Sho Source would make them for the Gen III/IV cars. The control arm box is stamped steel, and hitting it the wrong way with a floor jack can bend the crap out of it.
JR
I think the G3 rear control arm box is quite sturdy compared to the G1-2. I jack the car up there all the time and have not had any problems. Don't think you need a brace for the G3 and later.
Paul, I actually bent the box on my Sable, but my Taurus hasn't had that happen. I wonder if Ford put some sort of a plate behind the stamped steel to give it a bit more rigidity...
JR
The G3/4 design is different than then G1/2 design, and the G3/4 design is much stiffer. There has been a discussion about this before, and I have posted pictures of the G3/4 rear control box before with dimensions.
When I first started working on my Sable, I put the floor jack under the control arm box, but didn't have it aligned properly. The floor jack slipped after I had it a few pumps up (wheels still on the ground), and the back portion of it bent upwards just a bit. It wasn't anything serious...nothing that could have screwed up the alignment, but the sheet steel that it was stamped from just bent a little.
I don't know if it was operator error, stupidity, or material defect that caused the problem, though.
JR
so is it certain that the hbrace box will not fit on the gen3 cars. I know they dont need them but will it fit?
1 - 10 of 10 Posts
