Ok so here's the deal my rear drivers side window only goes up or down when its cold out but as soon as the temp goes up to about 50 degrees or so it wont do either i cant figure out why
so does anyone know why
its a g3 btw
Discussion Starter #2
come on someone has to know something
its really becoming a pain not to be able to roll it down except when it freezing
QUOTE (mscottc @ Mar 31 2009, 11:12 PM) index.php?act=findpost&pid=714246
its really becoming a pain not to be able to roll it down except when it freezing[/b]
Can you get to the window motor? if so, chill the motor with Freon TF "freeze spray" or CO2 if you have a buddy with an inter-cooler chiller and see if ti works, of so, go buy a new motor! if not, you problem is elsewhere. I think they have thermal breakers probably in the motor unit itself, and if so, likely not replaceable without replacing the whole motor :(
My 04 did the same thing.
I took off the drivers side panel, unplugged the wires from the power window switch (don't mix em up) and sprayed in some contact cleaner.
My window works fine now. :)
