1 - 10 of 10 Posts
I have a 1990 Ford Taurus that the back door is stuck shut because the outside door handle is broken, and the child lock is engaged. I was wondering if anyone knows any tricks to get the door unlock and turn off the child lock. thanks
See if you can shimmy a flat head screw driver into either side of the slits where the door handle itself goes into the door. See if you can shimmy and lift up on it enough to maybe unlatch the door? Otherwise the slim jim idea sounds good.
Looks like more and more Gen 1s are suffering from the same issue a lota 90s Camry's have, broken exterior door handles.
Since the handle is broken, lift or tear it out of the way, drill out the two rivets and remove the back half of the plastic. Then you can see the lever to operate the latch. Had a broken handle on mine, I can use my finger to open the door with the handle out of the way.
I got an auto lock-out tool set from harbor freight years ago that inc. a couple diff. size slim-jims & various other tools & gadgets for apprx. $10. Dont know the item or lot# or if they even carry it anymore as orig. pkging. is gone. Dont see it on their website. Sorry.
1 - 10 of 10 Posts
